int xxdevmap_dup(devmap_cookie_t handle, void *devprivate, devmap_cookie_t new_handle, void **new_devprivate);
This entry point is called when a device mapping is duplicated, for example, by a user process calling fork(2). The driver is expected to generate new driver private data for the new mapping.
handle is the mapping handle of the mapping being duplicated.
new_handle is the mapping handle of the mapping that was duplicated.
devprivate is a pointer to the driver private data associated with the mapping being duplicated.
*new_devprivate should be set to point to the new driver private data for the new mapping.
Mappings created with devmap_dup(9E) will, by default, have their mapping translations invalidated. This will force a call to the devmap_access(9E) entry point the first time the mapping is accessed.
Example 12-5 shows a devmap_dup(9E) routine.
static int xxdevmap_dup(devmap_cookie_t handle, void *devprivate, devmap_cookie_t new_handle, void **new_devprivate) { struct xxctx *ctxp = devprivate; struct xxstate *xsp = ctxp->xsp; struct xxctx *newctx; /* Create a new context for the duplicated mapping */ newctx = kmem_alloc(sizeof (struct xxctx), KM_SLEEP); newctx->xsp = xsp; newctx->handle = new_handle; newctx->offset = ctxp->offset; newctx->flags = ctxp->flags; newctx->len = ctxp->len; mutex_enter(&xsp->ctx_lock); if (ctxp->flags & MAP_PRIVATE) { newctx->context = kmem_alloc(XXCTX_SIZE, KM_SLEEP); bcopy(ctxp->context, newctx->context, XXCTX_SIZE); } else { newctx->context = xsp->ctx_shared; } mutex_exit(&xsp->ctx_lock); *new_devprivate = newctx; return(0); }
