Writing Device Drivers
ddi_dma_sync()
If a memory object has multiple mappings--such as for a device (through the DMA handle), and for the CPU--and one mapping is used to modify the memory object, the driver needs to call ddi_dma_sync(9F) to ensure that the modification of the memory object is complete before accessing the object through another mapping. ddi_dma_sync(9F) may also inform other mappings of the object that any cached references to the object are now stale. Additionally, ddi_dma_sync(9F) flushes or invalidates stale cache references as necessary.
Generally, the driver has to call ddi_dma_sync(9F) when a DMA transfer completes. The exception to this is that deallocating the DMA resources (ddi_dma_unbind_handle(9F)) does an implicit ddi_dma_sync(9F) on behalf of the driver.
	int ddi_dma_sync(ddi_dma_handle_t handle, off_t off,
 		size_t length, u_int type);
If the object is going to be read by the DMA engine of the device, the device's view of the object must be synchronized by setting cttype to DDI_DMA_SYNC_FORDEV. If the DMA engine of the device has written to the memory object, and the object is going to be read by the CPU, the CPU's view of the object must be synchronized by setting type to DDI_DMA_SYNC_FORCPU.
Here is an example of synchronizing a DMA object for the CPU:
	if (ddi_dma_sync(xsp->handle, 0, length, DDI_DMA_SYNC_FORCPU)
 		== DDI_SUCCESS) {
 		/* the CPU can now access the transferred data */
 	} else {
 		error handling
If the only mapping that concerns the driver is one for the kernel (such as memory allocated by ddi_dma_mem_alloc(9F)), the flag DDI_DMA_SYNC_FORKERNEL can be used. This is a hint to the system that if it can synchronize the kernel's view faster than the CPU's view, it can do so; otherwise, it acts the same as DDI_DMA_SYNC_FORCPU.
