Writing Device Drivers
Standard Character Device Drivers
Character device drivers normally perform I/O in a byte stream. They can also provide additional interfaces not present in block drivers, such as I/O control (ioctl(9E)) commands, memory mapping, and device polling. See Chapter 9, Drivers for Character Devices, for more information.
Byte-Stream I/O
The main task of any device driver is to perform I/O, and many character device drivers do what is called byte-stream or character I/O. The driver transfers data to and from the device without using a specific device address. This is in contrast to block device drivers, where part of the file system request identifies a specific location on the device.
The read(9E) and write(9E) entry points handle byte-stream I/O for standard character drivers. See "I/O Request Handling" for more information.
I/O Control
Many devices have characteristics and behavior that can be configured or tuned. The ioctl(2) system call and the ioctl(9E) driver entry point provide a mechanism for application programs to change and determine the status of a driver's configurable characteristics. For example, the baud rate of a serial communications port is usually configurable in this way.
The I/O control interface is open ended, enabling device drivers to define special commands for the device. The definition of the commands is entirely determined by the driver and is restricted only by the requirements of the application programs using the device and the device itself.
Certain classes of devices such as frame buffers or disks must support standard sets of I/O control requests. These standard I/O control interfaces are documented in the Solaris 2.7 Reference Manual. For example, fbio(7I) documents the I/O controls that frame buffers must support, and dkio(7I) documents standard disk I/O controls. See "Miscellaneous I/O Control " for more information on I/O control.
Note -
This manual does not cover I/O control commands.
Device Memory Mapping
For certain devices, such as frame buffers, it is more efficient for application programs to have direct access to device memory. Applications can map device memory into their address spaces using the mmap(2) system call. To support memory mapping, device drivers implement segmap(9E) and devmap(9E) entry points. For information on devmap(9E), see Chapter 11, Mapping Device or Kernel Memory. For information on segmap(9E), see Chapter 9, Drivers for Character Devices.
Drivers that define an devmap(9E) entry point usually do not define read(9E) and write(9E) entry points, as application programs perform I/O directly to the devices after calling mmap(2).
Device Polling
The poll(2) system call enables application programs to monitor or poll a set of file descriptors for certain conditions or events. poll(2) can be used to find out whether data are available to be read from the file descriptors or whether data may be written to the file descriptors without delay. Drivers referred to by these file descriptors must provide support for the poll(2) system call by implementing a chpoll(9E) entry point.
Drivers for communication devices such as serial ports should support polling, as they are used by applications that require synchronous notification of changes in read and write status. Many communications devices, however, are better implemented as STREAMS drivers.
