To assist device driver writers in allocating state structures, the Solaris 7 DDI/DKI provides a set of memory management routines called the software state management routines (also known as the soft state routines). These routines dynamically allocate, retrieve, and destroy memory items of a specified size, and hide all the details of list management in a multithreaded kernel. An item number is used to identify the desired memory item; this number can be (and usually is) the instance number assigned by the system.
The driver must provide a state pointer, which is used by the soft state system to create the list of memory items:
static void *statep;
Routines are provided to:
Initialize the provided state pointer - ddi_soft_state_init(9F)
Allocate space for a certain item - ddi_soft_state_zalloc(9F)
Retrieve a pointer to the indicated item - ddi_get_soft_state(9F)
Free the memory item - ddi_soft_state_free(9F)
Finish using the state pointer - ddi_soft_state_fini(9F)
When the module is loaded, the driver calls ddi_soft_state_init(9F) to initialize the driver state pointer, passing a hint indicating how many items to pre-allocate. If more items are needed, the driver will allocate them as necessary. The driver must call ddi_soft_state_fini(9F) when the driver is unloaded.
To allocate an instance of the soft state structure, the driver calls ddi_soft_state_zalloc(9F). Once the item is allocated, the driver calls ddi_get_soft_state(9F) to retrieve the pointer to the allocated structure. This is usually done when the device is attached. When the device is detached, the driver calls ddi_soft_state_free(9F) to free the memory.
See "Loadable Driver Interface" for an example use of these routines.
