Writing Device Drivers
Compiler Modes
Note the following compiler modes.
-Xa (ANSI C Mode)
This mode accepts ANSI C and Sun C compatibility extensions. In case of a conflict between ANSI and Sun C, the compiler issues a warning and uses ANSI C interpretations. This is the default mode.
-Xt (Transition Mode)
This mode accepts ANSI C and Sun C compatibility extensions. In case of a conflict between ANSI and Sun C, a warning is issued and Sun C semantics are used.
