Writing Device Drivers
Physical SBus Addresses
The SBus has 32 address bits, as described in the SBus Specification. Table 2-2 describes how the Ultra 2 uses the address bits.
Table 2-2 Ultra 2 SBus Address Bits
0 - 27
These bits are the SBus address lines used by an SBus card to address the contents of the card.
28 - 31
Used by the CPU to select one of the SBus slots. These bits generate the SlaveSelect lines.
This addressing scheme yields the Ultra 2 addresses shown in Table 2-1. Other implementations may use a different number of address bits.
The Ultra 2 has seven SBus slots, four of which are physical. Slots 0 through 3 are available for SBus cards. Slots 4-12 are reserved. The slots are used in the following way:
