The device tree can be displayed in two ways:
The prtconf(1M) command displays all of the device nodes in the device tree.
The /devices hierarchy is a representation of the device tree; use ls(1) to view it.
/devices displays only devices that have drivers configured into the system. prtconf(1M) shows all device nodes regardless of whether a driver for the device exists on the system or not.
The prtconf(1M) command (excerpted example follows) displays all the devices in the system:
SUNW,Ultra-1 ... pci, instance #0 ebus, instance #0 auxio (driver not attached) power (driver not attached) SUNW,pll (driver not attached) sc (driver not attached) se, instance #0 su, instance #0 su, instance #1 ecpp (driver not attached) fdthree (driver not attached) eeprom (driver not attached) flashprom (driver not attached) SUNW,CS4231 (driver not attached) network, instance #0 scsi, instance #0 disk (driver not attached) tape (driver not attached) sd, instance #0 sd, instance #1 (driver not attached) sd, instance #2 (driver not attached) sd, instance #3 (driver not attached) sd, instance #4 (driver not attached) sd, instance #5 (driver not attached) .... pci, instance #1 SUNW,UltraSPARC-II (driver not attached) SUNW,ffb (driver not attached) pseudo, instance #0
The /devices hierarchy provides a name space that represents the device tree. Following is an abbreviated listing of the /devices name space. The sample output corresponds to the example device tree and prtconf(1M) output shown previously.
/devices /devices/pseudo /devices/SUNW,ffb@1e,0:ffb0 /devices/pci@1f,4000/ebus@1 /devices/pci@1f,4000/scsi@3 /devices/pci@1f,4000/scsi@3:devctl /devices/pci@1f,4000/ebus@1/ecpp@14,3043bc:ecpp0 /devices/pci@1f,4000/ebus@1/se@14,400000:0,hdlc /devices/pci@1f,4000/ebus@1/se@14,400000:1,hdlc /devices/pci@1f,4000/ebus@1/se@14,400000:a /devices/pci@1f,4000/ebus@1/se@14,400000:a,cu /devices/pci@1f,4000/ebus@1/se@14,400000:b /devices/pci@1f,4000/ebus@1/se@14,400000:b,cu /devices/pci@1f,4000/ebus@1/SUNW,CS4231@14,200000:sound,audio /devices/pci@1f,4000/ebus@1/SUNW,CS4231@14,200000:sound,audioctl /devices/pci@1f,4000/scsi@3/sd@0,0:a /devices/pci@1f,4000/scsi@3/sd@0,0:a,raw
