When removing a package, a package that includes a driver must run rem_drv(1M) to complete the removal of the driver, after removing the driver binary and other components from a system. Here is an example package postremove script to run rem_drv(1M) to complete the driver removal.
#!/bin/sh # # @(#)postremove 1.1 PATH="/usr/bin:/usr/sbin:${PATH}" export PATH # # Driver info # DRV=<driver-name> REM_DRV=/usr/sbin/rem_drv # # Select the correct rem_drv options to execute. # rem_drv touches /reconfigure to cause the # next boot to be a reconfigure boot. # if [ "${BASEDIR}" = "/" ]; then # # On a running system, modify the # system files and remove the driver # REM_DRV_FLAGS="" else # # On a client, modify the system files # relative to BASEDIR # REM_DRV_FLAGS="-b ${BASEDIR}" fi ${REM_DRV} ${REM_DRV_FLAGS} ${DRV} exit 0
