Writing Device Drivers
Copying the Driver to a Module Directory
Device drivers reside in different directories depending on the platform they run on and whether they are needed at boot time. Platform-dependent device drivers reside in the following locations:
To install a driver, the driver and its configuration file must be copied to a drv directory in the module path. For example, to copy a driver to /usr/kernel/drv, type:
$ su# cp xx /usr/kernel/drv# cp xx.conf /usr/kernel/drv
Optionally Editing /etc/devlink.tab
If the driver creates minor nodes that do not represent disks, tapes, or ports (terminal devices), /etc/devlink.tab can be modified to cause devlinks(1M) to create logical device names in /dev. See devlink.tab(4) for a description of the syntax of this file.
Alternatively, logical names can be created by a program run at driver installation time.
