Writing Device Drivers
Check Use of Derived Types That Change Size Between 32-Bit and 64-Bit Environments
System derived types, such as size_t, should be used where possible so that the resulting variables make sense when passed between functions. The new derived types uintptr_t or intptr_t should be used as the integral type for pointers.
Fixed-width integer types are useful for representing explicit sizes of binary data structures or hardware registers, while fundamental C language data types, such as int, can still be used for loop counters or file descriptors.
Some system derived types represent 32-bit quantities on a 32-bit system but represent 64-bit quantities on a 64-bit system. Derived types that change size in this way include:
Drivers that use these derived types should pay particular attention to their use, particularly if they are assigning these values to variables of another derived type, such as a fixed-width type.
