To enable a 64-bit driver and a 32-bit application to share memory, the binary layout generated by the 64-bit driver must be the same as consumed by the 32-bit application.
To determine whether there is a model mismatch, devmap(9E) uses the model parameter to pass the data model type expected by the application. model is set to one of the following:
DDI_MODEL_ILP32 - Application uses the ILP32 data model
DDI_MODEL_LP64 - Application uses the LP64 data model
Example F-2 shows the devmap(9E) model parameter being passed to the ddi_model_convert_from(9F) function.
struct data { int len; caddr_t addr; }; xxdevmap(dev_t dev, devmap_cookie_t dhp, offset_t offset, size_t len, size_t *maplen, uint_t model); { struct data dtc; /* local copy for clash resolution */ struct data *dp = (struct data *)shared_area; #ifdef _MULTI_DATAMODEL switch (ddi_model_convert_from(model)) { case DDI_MODEL_ILP32: { struct data32 { int len; uint32_t *addr; } *da32p; da32p = (struct data32 *)shared_area; dp = &dtc; dp->len = da32p->len; dp->address = da32p->address; break; } case DDI_MODEL_NONE: break; } #endif /* _MULTI_DATAMODEL */ /* continues along using dp */ ... }
