Writing Device Drivers
When to Use Structure Macros
Macros only allow you to make in-place references to the fields of a data item. They do not provide a way to take separate code paths based on the data model. They should be avoided if the number of fields in the data structure is large or the frequency of references to these fields is high.
Because macros hide many of the differences between data models in the implementation of the macros, code written with this interface is generally easier to read.
When compiled as a 32-bit driver, the resulting code is compact without needing clumsy #ifdefs, while preserving type checking.
Macros are best suited for making in-place references to the fields of a data structure, particularly if the number of fields in the data structure is small and the frequency of references to these fields is low.
