Writing Device Drivers
Using Condition Variables
To use condition variables, follow these steps in the code path waiting for the condition:
  1. Acquire the mutex guarding the condition.
  2. Test the condition.
  3. If the test results do not allow the thread to continue, use cv_wait(9F) to block the current thread on the condition. cv_wait(9F) releases the mutex before blocking. Upon return from cv_wait(9F) (which will reacquire the mutex before returning), repeat the test.
  4. Once the test allows the thread to continue, set the condition to its new value. For example, set a device flag to busy.
  5. Release the mutex.
Follow these steps in the code path signaling the condition:
  2. Set the condition.
  3. Signal the blocked thread with cv_signal(9F).
  4. Release the mutex.
Example 4-1 uses a busy flag, and mutex and condition variables to force the read(9E) routine to wait until the device is no longer busy before starting a transfer.
Example 4-1 Using Mutexes and Condition Variables
static int
xxread(dev_t dev, struct uio *uiop, cred_t *credp)
	struct xxstate *xsp;
	mutex_enter(&xsp->mu);
	while (xsp->busy)
			cv_wait(&xsp->cv, &xsp->mu);
	xsp->busy = 1;
	mutex_exit(&xsp->mu);
	perform the data access
static u_int
xxintr(caddr_t arg);
	struct xxstate *xsp = (struct xxstate *)arg;
	xsp->busy = 0;
	cv_broadcast(&xsp->cv);
In Example 4-1, xxintr()( ) always calls cv_broadcast(9F), even if there are no threads waiting on the condition. This extra call can be avoided by using a want flag in the state structure, as shown in Example 4-2. Before a thread blocks on the condition variable (such as because the device is busy), it sets the want flag, indicating that it wants to be signaled when the condition occurs. When the condition occurs (the device finishes the transfer), the call to cv_broadcast(9F) is made only if the want flag is set.
Example 4-2 Using a want Flag
static int
	while (xsp->busy) {
			xsp->want = 1;
	xsp->busy = 1;
	perform error recovery
static u_int
	xsp->busy = 0;
	if (xsp->want) {
			xsp->want = 0;
