The driver must keep the framework informed of device state transitions from idle to busy or busy to idle. Where these transitions happen is entirely device specific. Some components are created and marked busy and never change. Some are created and never marked busy (components created by pm_create_components(9F) are created in an idle state). For example, a frame buffer currently supports two components: component 0 represents the frame buffer electronics and is always busy, and component 1 represents the monitor and is always idle (but dependent on the keyboard and mouse).
Component 0 represents the state of the device that would be lost if power is removed.
Some devices, such as the keyboard and mouse, are never marked busy but have their idle time reset each time a keystroke or mouse event is processed. The transitions from idle to busy and from busy to idle depend on the nature of the device and the abstraction represented by the specific component. For example, SCSI disk target drivers typically export a single component, which represents whether the SCSI target disk drive is spun up or not. It is marked busy whenever there is an outstanding request to the drive and idle when the last queued request finishes.
The following interfaces notify the Power Management framework of busy-idle state transitions.
