Writing Device Drivers
Device Power Management
To perform effective device power management, system software monitors the different components of the device and determines when they are not in use. Since only device drivers are able to determine when a device is idle, and only device drivers are able to reduce power consumption of a device, the Power Management framework exports interfaces to enable communication between the system software and the device driver.
The Solaris Power Management framework provides the following:
