Writing Device Drivers
scsi_pkt Structure
This structure contains the following fields:
		struct scsi_address		pkt_address;
 	opaque_t						pkt_private;
 	void							(*pkt_comp)(struct scsi_pkt *pkt);
 	u_int							pkt_flags;
 	int							pkt_time;
 	u_char						*pkt_scbp;
 	u_char						*pkt_cdbp;
 	ssize_t						pkt_resid;
 	u_int							pkt_state;
 	u_int							pkt_statistics;
 	u_char						pkt_reason;
pkt_address is the target device's address set by scsi_init_pkt(9F)
pkt_private is a place to store private data for the target driver. It is commonly used to save the buf(9S) pointer for the command.
pkt_comp is the address of the completion routine. The host bus adapter driver calls this routine when it has transported the command. This does not mean that the command succeeded; the target might have been busy or might not have responded before the time-out time elapsed (see the description for pkt_time field). The target driver must supply a valid value in this field, though it can be NULL if the driver does not want to be notified.
Note -
There are two different SCSI callback routines. The pkt_comp field identifies a completion callback routine, which is called when the host bus adapter completes its processing. There is also a resource callback routine, called when currently unavailable resources are likely to be available (as in scsi_init_pkt(9F)).
pkt_flags provides additional control information, for example, to transport the command without disconnect privileges (FLAG_NODISCON) or to disable callbacks (FLAG_NOINTR). See scsi_pkt(9S) for details.
pkt_time is a time-out value (in seconds). If the command is not completed within this time, the host bus adapter calls the completion routine with pkt_reason set to CMD_TIMEOUT. The target driver should set this field to longer than the maximum time the command might take. If the timeout is zero, no timeout is requested. Timeout starts when the command is transmitted on the SCSI bus.
pkt_scbp is a pointer to the SCSI status completion block; this is filled in by the host bus adapter driver.
pkt_cdbp is a pointer to the SCSI command descriptor block, the actual command to be sent to the target device. The host bus adapter driver does not interpret this field. The target driver must fill it in with a command that the target device can process.
pkt_resid is the residual of the operation. When allocating DMA resources for a command scsi_init_pkt(9F), pkt_resid indicates the number of bytes for which DMA resources could not be allocated because of DMA hardware scatter-gather or other device limitations. After command transport, pkt_resid indicates the number of data bytes not transferred; this is filled in by the host bus adapter driver before the completion routine is called.
pkt_state indicates the state of the command. The host bus adapter driver fills in this field as the command progresses. One bit is set in this field for each of the five following command states:
pkt_statistics contains transport-related statistics set by the host bus adapter driver.
pkt_reason gives the reason the completion routine was called. The main function of the completion routine is to decode this field and take the appropriate action. If the command completed--in other words, if there were no transport errors--this field is set to CMD_CMPLT; other values in this field indicate an error. After a command is completed, the target driver should examine the pkt_scbp field for a check condition status. See scsi_pkt(9S) for more information.
