Writing Device Drivers
scsi_device Structure
The HBA framework allocates and initializes a scsi_device(9S) structure for each instance of a target device before calling an HBA driver's tran_tgt_init(9E) entry point. This structure stores information about each SCSI logical unit, including pointers to information areas that contain both generic and device-specific information. There is one scsi_device(9S) structure for each target device instance attached to the system.
If the per-target initialization is successful (in other words, if either tran_tgt_init(9E) returns success or the vector is NULL), the HBA framework will set the target driver's per-instance private data to point to the scsi_device(9S) structure, using ddi_set_driver_private(9F).
The scsi_device(9S) structure contains the following fields:
struct scsi_address 				sd_address;			/* routing information */
 	dev_info_t						*sd_dev; 			/* device dev_info node */
 	kmutex_t							sd_mutex;			/* mutex used by device */
 	struct scsi_inquiry 		*sd_inq;
 	struct scsi_extended_sense	*sd_sense;
 	caddr_t							sd_private;			/* for driver's use */
sd_address is a data structure that is passed to the SCSI resource allocation routines.
sd_dev is a pointer to the target's dev_info structure.
sd_mutex is a mutex for use by the target driver. This is initialized by the HBA framework and can be used by the target driver as a per-device mutex. This mutex should not be held across a call to scsi_transport(9F) or scsi_poll(9F). See Chapter 4, Multithreading, for more information on mutexes.
sd_inq is a pointer for the target device's SCSI inquiry data. The scsi_probe(9F) routine allocates a buffer, fills it in, and attaches it to this field.
sd_sense is a pointer to a buffer to contain Request Sense data from the device. The target driver must allocate and manage this buffer itself; see the target driver's attach(9E) routine in "attach()" for more information.
sd_private is a pointer field for use by the target driver. It is commonly used to store a pointer to a private target driver state structure.
