The _fini(9E) function is called when the system is about to try to unload the SCSI HBA driver. The _fini(9E) function must call mod_remove(9F) to determine if the driver can be unloaded. If mod_remove(9F) returns 0, the module can be unloaded, and the HBA driver must deallocate any global resources allocated in _init(9E) and must call scsi_hba_fini(9F).
_fini(9E) must return the value returned by mod_remove(9F).
The HBA driver must not free any resources or call scsi_hba_fini(9F) unless mod_remove(9F) returns 0.
The _fini(9E) function in Example 14-2 shows how a SCSI HBA driver deallocates a global mutex initialized in _init(9E).
int _fini(void) { int err; if ((err = mod_remove(&modlinkage)) == 0) { mutex_destroy(&isp_global_mutex); scsi_hba_fini(&modlinkage); ddi_soft_state_fini(&isp_state); } return (err); }
