Writing Device Drivers
Resource Allocation
tran_init_pkt(9E)
The tran_init_pkt(9E) entry point is the HBA driver function that allocates and initializes, on behalf of the target driver, a scsi_pkt(9S) structure and DMA resources for a target driver request.
The tran_init_pkt(9E) entry point is called when the target driver calls the SCSA function scsi_init_pkt(9F).
Each call of the tran_init_pkt(9E) entry point is a request to perform one or more of three possible services:
Allocation and Initialization of a scsi_pkt(9S) Structure
The tran_init_pkt(9E) entry point must allocate a scsi_pkt(9S) structure if pkt is NULL through scsi_hba_pkt_alloc(9F).
scsi_hba_pkt_alloc(9F) allocates the following:
The scsi_pkt(9S) structure members, as well as pkt itself, must be initialized to zero except for the following members: pkt_scbp (status completion), pkt_cdbp (CDB), pkt_ha_private (HBA driver private data), pkt_private (target driver private data). These members are pointers to memory space where the values of the fields are stored, as illustrated in Figure 14-5. For more information, refer to "scsi_pkt Structure".
Figure 14-5 scsi_pkt(9S) Structure Pointers
Graphic
Example 14-4 provides an example of allocation and initialization of a scsi_pkt(9S) structure.
Example 14-4 HBA Driver Initialization of a SCSI Packet Structure
static struct scsi_pkt 							*
isp_scsi_init_pkt(
	struct scsi_address						*ap,
	struct scsi_pkt						*pkt,
	struct buf						*bp,
	int						cmdlen,
	int						statuslen,
	int						tgtlen,
	int						flags,
	int						(*callback)(),
	caddr_t						arg)
	struct isp_cmd						*sp;
	struct isp						*isp;
	struct scsi_pkt						*new_pkt;
	ASSERT(callback == NULL_FUNC || callback == SLEEP_FUNC);
	isp = (struct isp *)ap->a_hba_tran->tran_hba_private;
	 * First step of isp_scsi_init_pkt:  pkt allocation
	if (pkt == NULL) {
	   	pkt = scsi_hba_pkt_alloc(isp->isp_dip, ap, cmdlen,
				statuslen, tgtlen, sizeof (struct isp_cmd),
				callback, arg);
	   	if (pkt == NULL) {
			    return (NULL);
	   	sp = (struct isp_cmd *)pkt->pkt_ha_private;
		    * Initialize the new pkt
	   	sp->cmd_pkt					= pkt;
	   	sp->cmd_flags					= 0;
	   	sp->cmd_scblen					= statuslen;
	   	sp->cmd_cdblen					= cmdlen;
	   	sp->cmd_dmahandle					= NULL;
	   	sp->cmd_ncookies					= 0;
	   	sp->cmd_cookie					= 0;
	   	sp->cmd_cookiecnt					= 0;
	   	sp->cmd_nwin					= 0;
	   	pkt->pkt_address					= *ap;
	   	pkt->pkt_comp					= (void (*)())NULL;
	   	pkt->pkt_flags					= 0;
	   	pkt->pkt_time					= 0;
	   	pkt->pkt_resid					= 0;
	   	pkt->pkt_statistics	=	 0;
	   	pkt->pkt_reason					= 0;
	   	new_pkt = pkt;
	} else {
	   	new_pkt = NULL;
	 * Second step of isp_scsi_init_pkt:  dma allocation/move
	if (bp && bp->b_bcount != 0) {
	   	if (sp->cmd_dmahandle == NULL) {
			   if (isp_i_dma_alloc(isp, pkt, bp,
			       flags, callback) == 0) {
				   if (new_pkt) {
				       	scsi_hba_pkt_free(ap, new_pkt);
				   return ((struct scsi_pkt *)NULL);
	   	} else {
			   ASSERT(new_pkt == NULL);
			   if (isp_i_dma_move(isp, pkt, bp) == 0) {
	return (pkt);
Allocation of DMA Resources
If bp is not NULL and bp->b_bcount is not zero and DMA resources have not yet been allocated for this scsi_pkt(9S), the tran_init_pkt(9E) entry point must allocate DMA resources for a data transfer. The HBA driver needs to keep track of whether DMA resources have been allocated for a particular command with a flag bit or a DMA handle in the per-packet HBA driver private data.
By setting the PKT_DMA_PARTIAL flag in the pkt, the target driver indicates it can accept breaking up the data transfer into multiple SCSI commands to accommodate the complete request. This may be necessary if the HBA hardware scatter-gather capabilities or system DMA resources are insufficient to accommodate the complete request in a single SCSI command.
If the PKT_DMA_PARTIAL flag is set, the HBA driver may set the DDI_DMA_PARTIAL flag when allocating DMA resources (using, for example, ddi_dma_buf_bind_handle(9F)) for this SCSI command. The DMA attributes used when allocating the DMA resources should accurately describe any constraints placed on the ability of the HBA hardware to perform DMA. If the system can only allocate DMA resources for part of the request, ddi_dma_buf_bind_handle(9F) will return DDI_DMA_PARTIAL_MAP.
The tran_init_pkt(9E) entry point must return the amount of DMA resources not allocated for this transfer in the field pkt_resid.
A target driver may make one request to tran_init_pkt(9E) to simultaneously allocate both a scsi_pkt(9S) structure and DMA resources for that pkt. In this case, if the HBA driver is unable to allocate DMA resources, it must free the allocated scsi_pkt(9S) before returning. The scsi_pkt(9S) must be freed by calling scsi_hba_pkt_free(9F).
The target driver may first allocate the scsi_pkt(9S) and allocate DMA resources for this pkt at a later time. In this case, if the HBA driver is unable to allocate DMA resources, it must not free pkt. The target driver in this case is responsible for freeing the pkt.
Example 14-5 HBA Driver Allocation of DMA Resources
static int
isp_i_dma_alloc(
	struct isp				*isp,
	struct buf				*bp,
	int				flags,
	int				(*callback)())
	struct isp_cmd	*sp				= (struct isp_cmd *)pkt->pkt_ha_private;
	int				dma_flags;
	ddi_dma_attr_t				tmp_dma_attr;
	int				(*cb)(caddr_t);
	int				i;
	if (bp->b_flags & B_READ) {
	   	sp->cmd_flags &= ~CFLAG_DMASEND;
	   	dma_flags = DDI_DMA_READ;
	} else {
	   	sp->cmd_flags |= CFLAG_DMASEND;
	   	dma_flags = DDI_DMA_WRITE;
	if (flags & PKT_CONSISTENT) {
	   	sp->cmd_flags |= CFLAG_CMDIOPB;
	   	dma_flags |= DDI_DMA_CONSISTENT;
	if (flags & PKT_DMA_PARTIAL) {
	   	dma_flags |= DDI_DMA_PARTIAL;
	tmp_dma_attr = isp_dma_attr;
	tmp_dma_attr.dma_attr_burstsizes = isp->isp_burst_size;
	cb = (callback == NULL_FUNC) ? DDI_DMA_DONTWAIT :
DDI_DMA_SLEEP;
	if ((i = ddi_dma_alloc_handle(isp->isp_dip, &tmp_dma_attr,
	  	cb, 0, &sp->cmd_dmahandle)) != DDI_SUCCESS) {
		switch (i) {
		case DDI_DMA_BADATTR:
			bioerror(bp, EFAULT);
			return (0);
		case DDI_DMA_NORESOURCES:
			bioerror(bp, 0);
			return (0);
	i = ddi_dma_buf_bind_handle(sp->cmd_dmahandle, bp, dma_flags,
		cb, 0, &sp->cmd_dmacookies[0], &sp->cmd_ncookies);
	switch (i) {
	case DDI_DMA_PARTIAL_MAP:
		if (ddi_dma_numwin(sp->cmd_dmahandle, &sp->cmd_nwin) ==
		    		DDI_FAILURE) {
			cmn_err(CE_PANIC, "ddi_dma_numwin() failed\n");
		if (ddi_dma_getwin(sp->cmd_dmahandle, sp->cmd_curwin,
		    &sp->cmd_dma_offset, &sp->cmd_dma_len,
		    &sp->cmd_dmacookies[0], &sp->cmd_ncookies) ==
		   		DDI_FAILURE) {
			cmn_err(CE_PANIC, "ddi_dma_getwin() failed\n");
		goto get_dma_cookies;
	case DDI_DMA_MAPPED:
		sp->cmd_nwin = 1;
		sp->cmd_dma_len = 0;
		sp->cmd_dma_offset = 0;
get_dma_cookies:
		i = 0;
		sp->cmd_dmacount = 0;
		for (;;) {
			sp->cmd_dmacount += sp->cmd_dmacookies[i++].dmac_size;
			if (i == ISP_NDATASEGS || i == sp->cmd_ncookies)
				break;
			ddi_dma_nextcookie(sp->cmd_dmahandle,
				&sp->cmd_dmacookies[i]);
		sp->cmd_cookie = i;
		sp->cmd_cookiecnt = i;
		sp->cmd_flags |= CFLAG_DMAVALID;
		pkt->pkt_resid = bp->b_bcount - sp->cmd_dmacount;
		return (1);
		bioerror(bp, 0);
		break;
	case DDI_DMA_NOMAPPING:
		break;
	case DDI_DMA_TOOBIG:
		bioerror(bp, EINVAL);
		break;
	case DDI_DMA_INUSE:
		cmn_err(CE_PANIC, "ddi_dma_buf_bind_handle:"
			" DDI_DMA_INUSE impossible\n");
	default:
			" 0x%x impossible\n", i);
	ddi_dma_free_handle(&sp->cmd_dmahandle);
	sp->cmd_flags &= ~CFLAG_DMAVALID;
	return (0);
Reallocation of DMA Resources for Next Portion of Data Transfer
For a previously allocated packet with data remaining to be transferred, the tran_init_pkt(9E) entry point must reallocate DMA resources when the following conditions apply:
When reallocating DMA resources to the next portion of the transfer, tran_init_pkt(9E) must return the amount of DMA resources not allocated for this transfer in the field pkt_resid.
If an error occurs while attempting to move DMA resources, tran_init_pkt(9E) must not free the scsi_pkt(9S). The target driver in this case is responsible for freeing the pkt.
If the callback parameter is NULL_FUNC, the tran_init_pkt(9E) entry point must not sleep or call any function which may sleep. If the callback parameter is SLEEP_FUNC and resources are not immediately available, the tran_init_pkt(9E) entry point should sleep until resources are available, unless the request is impossible to satisfy.
Example 14-6 HBA Driver DMA Resource Reallocation
static int
isp_i_dma_move(
	struct isp						*isp,
	struct buf						*bp)
	int		i;
	ASSERT(sp->cmd_flags & CFLAG_COMPLETED);
	sp->cmd_flags &= ~CFLAG_COMPLETED;
	 * If there are no more cookies remaining in this window,
	 * must move to the next window first.
	if (sp->cmd_cookie == sp->cmd_ncookies) {
		 * For small pkts, leave things where they are
		if (sp->cmd_curwin == sp->cmd_nwin && sp->cmd_nwin == 1)
			return (1);
		 * At last window, cannot move
		if (++sp->cmd_curwin >= sp->cmd_nwin)
			return (0);
				DDI_FAILURE)
			return (0);
		sp->cmd_cookie = 0;
	} else {
		 * Still more cookies in this window - get the next one
			&sp->cmd_dmacookies[0]);
	 * Get remaining cookies in this window, up to our maximum
	i = 0;
	for (;;) {
		sp->cmd_cookie++;
			break;
	return (1);
tran_destroy_pkt(9E)
The tran_destroy_pkt(9E) entry point is the HBA driver function that deallocates scsi_pkt(9S) structures. The tran_destroy_pkt(9E) entry point is called when the target driver calls scsi_destroy_pkt(9F).
The tran_destroy_pkt(9E) entry point must free any DMA resources allocated for the packet. Freeing the DMA resources causes an implicit DMA synchronization if any cached data remained after the completion of the transfer. The tran_destroy_pkt(9E) entry point frees the SCSI packet itself by calling scsi_hba_pkt_free(9F).
Example 14-7 HBA Driver tran_destroy_pkt(9E) Entry Point
static void
isp_scsi_destroy_pkt(
	struct scsi_pkt		*pkt)
	 * Free the DMA, if any
	if (sp->cmd_flags & CFLAG_DMAVALID) {
		(void) ddi_dma_unbind_handle(sp->cmd_dmahandle);
	 * Free the pkt
	scsi_hba_pkt_free(ap, pkt);
tran_sync_pkt(9E)
The tran_sync_pkt(9E) entry point is the HBA driver function that synchronizes the DMA object allocated for the scsi_pkt(9S) structure before or after a DMA transfer. The tran_sync_pkt(9E) entry point is called when the target driver calls scsi_sync_pkt(9F).
If the data transfer direction is a DMA read from device to memory, tran_sync_pkt(9E) must synchronize the CPU's view of the data. If the data transfer direction is a DMA write from memory to device, tran_sync_pkt(9E) must synchronize the device's view of the data.
Example 14-8 HBA Driver tran_sync_pkt(9E) Entry Point
static void
isp_scsi_sync_pkt(
	   	(void)ddi_dma_sync(sp->cmd_dmahandle, sp->cmd_dma_offset,
			sp->cmd_dma_len,
			(sp->cmd_flags & CFLAG_DMASEND) ?
			DDI_DMA_SYNC_FORDEV : DDI_DMA_SYNC_FORCPU);
tran_dmafree(9E)
The tran_dmafree(9E) entry point is the HBA driver function that deallocates DMA resources allocated for a scsi_pkt(9S) structure. The tran_dmafree(9E) entry point is called when the target driver calls scsi_dmafree(9F).
tran_dmafree(9E) must free only DMA resources allocated for a scsi_pkt(9S) structure, not the scsi_pkt(9S) itself. Freeing the DMA resources implicitly performs a DMA synchronization.
Note -
The scsi_pkt(9S) will be freed in a separate request to tran_destroy_pkt(9E). Because tran_destroy_pkt(9E) must also free DMA resources, it is important that the HBA driver keep accurate note of whether scsi_pkt(9S) structures have DMA resources allocated.
Example 14-9 HBA Driver tran_dmafree(9E) Entry Point
static void
isp_scsi_dmafree(
	   	(void)ddi_dma_unbind_handle(sp->cmd_dmahandle);
