SCSA defines a number of HBA driver entry points, listed in Table 14-1. These entry points are called by the system when configuring a target driver instance connected to the HBA driver, or when the target driver makes a SCSA request. See "SCSA HBA Entry Points" for more information.
Table 14-1 SCSA HBA Entry Point Summary
Function Name |
Called as a Result of |
tran_tgt_init(9E) |
System attaching target device instance |
tran_tgt_probe(9E) |
Target driver calling scsi_probe(9F) |
tran_tgt_free(9E) |
System detaching target device instance |
tran_start(9E) |
Target driver calling scsi_transport(9F) |
tran_reset(9E) |
Target driver calling scsi_reset(9F) |
tran_abort(9E) |
Target driver calling scsi_abort(9F) |
tran_getcap(9E) |
Target driver calling scsi_ifgetcap(9F) |
tran_setcap(9E) |
Target driver calling scsi_ifsetcap(9F) |
tran_init_pkt(9E) |
Target driver calling scsi_init_pkt(9F) |
tran_destroy_pkt(9E) |
Target driver calling scsi_destroy_pkt(9F) |
tran_dmafree(9E) |
Target driver calling scsi_dmafree(9F) |
tran_sync_pkt(9E) |
Target driver calling scsi_sync_pkt(9F) |
tran_reset_notify(9E) |
Target driver calling scsi_reset_notify(9F) |
