Writing Device Drivers
tran_reset(9E)
The tran_reset(9E) entry point for a SCSI HBA driver is called to reset either the SCSI bus or a particular SCSI target device. This entry point is called when a target driver calls scsi_reset(9F).
The tran_reset(9E) entry point must reset the SCSI bus if level is RESET_ALL. If level is RESET_TARGET, just the particular target or logical unit must be reset.
Active commands affected by the reset must be marked with pkt_reason CMD_RESET, and with pkt_statistics OR'd with either STAT_BUS_RESET or STAT_DEV_RESET, depending on the type of reset.
Commands in the transport layer, but not yet active on the target, must be marked with pkt_reason CMD_RESET, and with pkt_statistics OR'd with either STAT_ABORTED.
