Solaris 7 (SPARC Platform Edition) Installation Library
Example: Installing Software From a Mounted CD
The following example shows a command to install the SUNWaudio package from a mounted Solaris CD. The example also shows the use of the pkgchk command to verify that the package files were installed properly.
Note -
The name of this product is Solaris 7 but code and path or package path names may use Solaris 2.7 or SunOS 5.7. Always follow the code or path as it is written.
# /usr/sbin/pkgadd -d /cdrom/cdrom0/s0/Solaris_2.7 SUNWaudio.
Installation of <SUNWaudio> was successful.
# pkgchk -v SUNWaudio
