Solaris 7 (SPARC Platform Edition) Installation Library
Example: Removing Software From a System
The following example shows a command to remove the SUNWaudio package from a system. The example also shows the use of the pkgchk command to verify that the package files were removed.
# /usr/sbin/pkgrm SUNWaudio
The following package is currently installed:
   SUNWaudio       Audio applications^M
                   (sparc) 3.0,REV=1.2.13^M
Do you want to remove this package? y
Removal of <SUNWaudio> was successful.
# pkgchk -v SUNWaudio
WARNING: no pathnames were associated with <SUNWaudio>
