Solaris 7 (SPARC Platform Edition) Installation Library
Hardware and Software Requirements
Before you start the installation process, verify that the systems on which you plan to install AnswerBook2 server software meet the hardware and software requirements listed in Table 8-2 and Table 8-3.
Table 8-2 Hardware and Software Requirements
Documentation server system hardware
SPARCstationTM 2 computer or higher (SPARCstation 5 computer recommended)
Intel-based personal computer
Operating environment
Solaris 7 (for SPARC or x86, as appropriate)
Admin GUI and AnswerBook2 client viewer
Any HTML 3.2-compliant browser, such as Netscape Navigator, HotJava, or Lynx
Table 8-3 Disk Space Requirements Table
Directory Path
Contains executable files, server processing files, library files, and graphics and document source files for the product interface.
26.0 Megabytes
Contains catalog files and log files, if logging functions are enabled.
5.0 Megabytes (recommended - grows as server is used)
Server start-up file
0.01 Megabytes
In addition, you need to set aside some amount of disk space (600 Megabytes recommended) for the actual book files. The exact amount of space depends on the specific collections. For a list of collections available on the Solaris 7 Documentation CD, see the README file located on that CD.
