Solaris 7 (SPARC Platform Edition) Installation Library
To Back Up a System
  1. Become superuser.
  2. Shut down the system.
    # init 0
  3. Bring the system to run-level S (single-user mode).
    ok boot -s
  4. (Optional) Check the file system for consistency with the fsck command.
    Running the fsck command using the -m option checks for file system consistency. For example, power failure can leave files in an inconsistent state.
    # fsck -m /dev/rdsk/device-name
  5. (Optional)If you will be backing up file systems onto a remote tape drive:
    1. Add the following entry to the ./rhosts file of the system that is initiating the backup:
      host root
    2. Verify that the host name added to the /.rhosts file above is accessible via the local /etc/inet/hosts file or available through an NIS or NIS+ name server.
  6. Identify the device name of the tape drive.
    The default tape drive is /dev/rmt/0.
  7. Insert a tape that is not write-protected into the tape drive.
  8. Back up file systems using one of the ufsdump commands listed in Table 5-2.
    Table 5-2 Full Backup Commands
    To Do Full Backups To ...
    Use This Command ...
    Local diskette
    ufsdump9ucf /vol/dev/ files_to_backup
    Local cartridge tape drive
    ufsdump9ucf /dev/rmt files_to_backup
    Remote cartridge tape drive
    ufsdump0ucf remote_host:/ files_to_backup
  9. When prompted, remove the tape and replace it with the next volume.
  10. Label each tape with the volume number, level, date, system name, and file system.
  11. Bring the system back to run-level 3 by pressing Control-D.
  12. Verify the backup was successful by using the ufsrestore command to display the tape contents.
