Use Solaris Web Start in the usual way, selecting the desired software and configurations, or accepting the defaults.
Solaris Web Start checks your selections against the image on the install server. If the software you request exists on the install server, it is transferred over the network and installed on the client. If a particular program you requested does not exist on the install server, Solaris Web Start prompts you to supply the appropriate CD-ROM.
