Solaris 7 (SPARC Platform Edition) Installation Library
XIL 1.4 Runtime Environment
The XIL library is an imaging API that provides a basic set of functions for imaging and video applications. The library provides a strategy for low-level software interfaces (foundation libraries) and enables APIs and API developers to port their code to these foundation libraries.
The XIL 1.4 runtime environment (RTE) should be installed if users at your site are running imaging applications. Whether an application requires the XIL RTE is not always obvious; therefore, you should install the XIL RTE if you are installing either OpenWindows or CDE software, since an application may reference the XIL libraries.
The XIL developer components are now separate from Solaris and are available free of charge on Sun's web site: The developer components are the following:
The XIL runtime libraries is included to ensure continuing support for applications employing XIL.
The XIL RTE has been improved with the following new functionality.
