Solaris Common Desktop Environment: User's Guide
To Find an Alias Card
  1. Open Address Manager.
  2. Open the Search menu and ensure that the following menu items are selected:
    • Personal Aliases
    • System Aliases
  3. Type your search text in the box provided.
    Your search text should be a full or partial email alias such as fredj@jupiter or fredj.
  4. When you are satisfied with the search text you have entered and the types of cards you are searching for, click the search (magnifying glass) icon
    Address Manager searches in the specified card folders for all occurrences of the specified text. Each time it finds a card matching the search criteria, it lists it in the Found drop-down box.
    Tip -
    If no matching cards are found, refine the search text or the card types you are searching for and try again.
  5. Use the Found drop-down box to browse through any cards found to identify the required email aliases.
    The Actions menu will list the available actions for each card type selected.
