Solaris Common Desktop Environment: User's Guide
To Edit a Personal Address Card
  1. Display the card you want to edit by searching for it and then selecting it in the Found drop-down box.
  2. Edit the text in the scrolling pane.
  3. When you are satisfied with the changes you have made, choose Save from the Card menu.
    Address Manager saves the changes to the card, which resides in the personal cards folder.
