Solaris Common Desktop Environment: User's Guide
To Start Audio With the Waveform Displayed
  1. Choose Startup from the Options menu.
    The Options dialog box is displayed, with Startup selected as the Category. If the Options dialog box is already displayed, choose Startup from the Category menu.
  2. Click Waveform View.
  3. Click OK.
    The Options dialog box closes. The next time you start Audio the waveform will be displayed.
