Click the Window menu button.
The Window menu appears.
Choose Occupy Workspace from the Window menu.
In the Workspaces list of the Occupy Workspace dialog box, select the workspaces in which you want the window to appear.
To select more than one contiguous workspace name in the list, hold down Shift while you click.
To select discontiguous workspace names in the list, hold down Control while you click.
Click a selected workspace to deselect it.
To place the window in every workspace, click the All Workspaces button.
Click OK.
To display the Window menu, press Alt+Spacebar.
Press the Down Arrow key to select Occupy Workspace, then press Return.
The Occupy Workspace dialog box appears.
Press Tab until the keyboard focus, as shown by the highlight, is in the Workspaces list.
Select the workspaces in which you want the window to appear:
Press Down Arrow or Up Arrow to move through the list.
To select more than one workspace, press Shift+Down Arrow or Shift+Up Arrow.
Press Return.
