Solaris Common Desktop Environment: User's Guide
To Select a List Item
A selected list item becomes highlighted. The highlighted item is acted upon when you click a button, such as OK.
Mouse
  1. Click the list item.
    In a multiple-selection list, hold down Shift while you click the items.
    To deselect an item, click it again.
  2. Click a button, such as OK.
    In some lists, double-clicking an item selects the item and chooses the default command.
    Graphic
Keyboard
  1. Press Tab to move to the list.
  2. Select the list item:
    • In a single-selection list, use the arrow keys to reach your choice.
    • In a multiple-selection list, use the arrow keys to reach your first selection, then press Shift+Up Arrow or Shift+Down Arrow.
    To deselect an item, press the Spacebar.
  3. Press Tab to move to a button, such as OK or Apply, then press Return.
