Solaris Common Desktop Environment: User's Guide
Pop-up Menus
  1. Press Alt+Tab until the keyboard focus is on the application window or workspace object.
  2. Press Shift+F10 to display the pop-up menu.
  3. Press the key for the item's mnemonic.
    Or, press Down Arrow to move to the item, then press Return.
    To close a menu without choosing an item, press Esc.
    For more information about using your keyboard for desktop navigation, refer to Appendix A, Keyboard Shortcuts for the Desktop.
