The Front Panel contains a number of controls, or program icons. Some are on the main panel, which is displayed by default, and others are on subpanels, which can be displayed by clicking a tab marked by a triangle.
You run an application by clicking mouse button 1 on its control.
For instructions on running applications from the Front Panel or for adding and manipulating controls on the Front Panel, see "Front Panel Applications" and "Customizing the Front Panel".
