Solaris Common Desktop Environment: User's Guide
  1. Press Alt+Spacebar to display the Window menu.
  2. Press M, the menu's mnemonic for Move.
  3. Press the arrow keys to relocate the window or icon.
    Hold down Control while you press an arrow key to speed up the movement of the window or icon.
  4. When you've moved the window or icon to where you want it, press Return.
To cancel the move operation, press Esc.
