Solaris Common Desktop Environment: User's Guide
sdtcm_convert
Usesdtcm_convert to convert Calendar data format, prune a calendar, or check data integrity. Use it to convert version 3 (OpenWindows) calendar data format to version 4 (the extensible calendar data format), and vice versa.
Note -
sdtcm_convert is automatically invoked when performing an OS upgrade to 2.6.
sdtcm_convert must be run by superuser or the owner of the calendar. Superuser can run sdtcm_convert on any calendar; a regular user can only run sdtcm_convert on his or her own calendar. Note that sdtcm_convert can be used only on calendars located on the local host.
The version 3 data format is fixed and limited. In order to take advantage of the new features supported by the calendar API, version 3 calendars should be converted to the version 4 data format.
Note -
OpenWindows Calendar Manager does not support the version 4 data format. If you need to switch back to OpenWindows Calendar Manager and you have a version 4 calendar, you should convert your calendar to the version 3 data format before switching the server. Be aware, however, that data not supported in the version 3 data format (for example, all calendar attributes except the access list, entry attributes such as date of creation or date of last update, and so on) will be lost.
Options for sdtcm_convert are listed and described below.
Note -
The data version of a calendar is displayed in the About Calendar dialog box of Calendar, accessible from the Help menu.
Examples
To convert the calendar user1 to version 4 data format and also prune the calendar:
% sdtcm_convert -v 4 -s 1/1/94 user1
To check data integrity of the calendar user1:
% sdtcm_convert user1
If no option is specified, sdtcm_convert will check the calendar file for data integrity.
