This procedure opens a terminal emulator window with the same current folder as the File Manager window. This is a quick way to type a command to affect the contents of the folder you are currently viewing.
Choose Open Terminal from the File menu.
You must have execute permission for a folder before you can open a Terminal window from it.
To find out how to use terminal emulators, see Chapter 12, Using Terminal .
