Solaris Common Desktop Environment: User's Guide
To View Files and Folders on a Diskette
  1. Insert the diskette into a disk drive.
  2. Select Open Floppy from the Files subpanel on the Front Panel, or from the File Manager File menu.
    If the diskette is formatted and readable by the system (see "Supported Formats"), File Manager displays a view of the diskette's contents. If the diskette is unformatted or is unreadable by the system, File Manager displays the Format Floppy dialog box.
    Note -
    If your system has more than one disk drive, File Manager opens one window for each readable diskette you insert when you choose Open Floppy from the File menu.
