Solaris Common Desktop Environment: User's Guide
To Move Files or Folders to a Diskette
  1. Select the icon for the file or folder you want to move.
  2. Choose Move to from the Selected menu.
    The Move Object dialog box appears.
  3. Type a full path name in the Destination Folder text field.
    Use /floppy as the directory name. For example, if you want to move the file report onto a diskette named john, you would type /floppy/john.
  4. Click OK or press Return.
    Note -
    You cannot move files or folders to a CD-ROM.
