Solaris Common Desktop Environment: User's Guide
Front Panel Pop-Up Menus
Each control in the Front Panel has a pop-up menu. The menu is different for each control.
To Display a Front Panel Pop-Up Menu
    Press mouse button 3 over the control.
    The control's pop-up menu is displayed.
Contents of the Pop-Up Menus
The contents of the pop-up menu depend on the behavior of the control and its location.
Main Panel Controls
If the control starts an application, the first entry in the menu is a command that starts the application. Choosing the menu item has the same effect as clicking the control.
In addition, the pop-up menu may contain the following items:
Switch Area
The switch area is the portion of the workspace switch not occupied by other controls or workspace buttons.
The switch area pop-up menu contains the following items:
Workspace Buttons
Use the workspace buttons to change workspaces. Each button has its own menu.
The workspace button pop-up menu includes the following items:
Subpanel Controls
The pop-up menus for subpanels include a command for making the control the current Main Panel control.
The pop-up menu for subpanel controls includes the following items:
