System administrators will find Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide (available via the AnswerBook2 viewer) useful for resolving configuration and administration issues.
System administrators investigating possible bugs should register with SunSolveTM, the Sun Microsystems online information, FAQ, and patch service; click SunSolve Online for more details. For help with specific problems that may require interaction with technical support, click on Solaris Support.
The following table describes the Help subpanel controls.
Table 4-10 Help Subpanel Controls
Icon |
Name |
Click Behavior |
Drop Behavior |
Opens a Help Viewer window displaying the top level of help information |
Dropping a master volume file (*.sdl) opens that help volume |
SunSolve Online | Opens a browser for the Sun Microsystems documentation and FAQ web site | None | |
Solaris Support | Opens a browser for the Sun Microsystems download site for patches, and technical support | None | |
Information | Opens the Information folder in Application Manager | None | |
Desktop Introduction | Displays the Introducing the Desktop help volume | None | |
Displays the Front Panel help volume |
None |
Provides on-item help for the Front Panel. Click this control, then click the control on which you want help. |
None |
AnswerBook2 |
Displays the AnswerBook2 viewer if you have AnswerBook2 installed. |
None |
