When you click System Info on the Hosts subpanel, the Workstation Information dialog box is displayed. The information in this dialog box is typically of interest to system administrators and technical support agents. It includes:
User identification
System identification
Memory usage and allocation
Version identification for operating environment and CDE
Current session information
You cannot change the amount of physical memory allocated using Workstation Information. For information on setting the swap space, see the swap(1M) man page.
