Solaris Common Desktop Environment: User's Guide
To Remove All User Customizations
Note -
This procedure does not affect advanced customizations made by manually editing Front Panel configuration files.
  1. Open Application Manager and double-click the Desktop_Controls application group icon.
  2. Double-click Restore Front Panel.
    The screen will go blank for several seconds while the Workspace Manager is restarted.
    The Restore Front Panel action removes all customization made using:
    • The Install Icon control
    • The Front Panel's pop-up menus
