Solaris Common Desktop Environment: User's Guide
Printing Configuration
The Print dialog box displays the name of your default printer. You can change the default printer name by modifying the LPDEST environment variable. You can also change the printer for a specific application by modifying the application's application defaults file.
To Set the Printer Resource for an Application
    Edit your HomeDirectory/.Xdefaults file by adding this resource:
application_name*printer             printer.name
If you do not have an .Xdefaults file, create the file in your home directory.
Example
You want to direct all printed help topics of an application named ImageScan to a printer named laser2 rather than to your default printer.
Add this resource to your .Xdefaults file:
ImageScan*printer:             laser2
