Select the area of the icon you want to resize using the Selection tool.
Choose Scale from the Edit menu.
Drag a box that defines the size and shape that you want the scaled image to be.
The size of the box is shown in the upper right area. This determines how the selected portion of the image will be scaled; it does not determine where to place the results.
Position the outline where you want to paste the scaled copy, and then click.
