Solaris Common Desktop Environment: User's Guide
To Scale an Image
To enlarge or reduce an image proportionally:
  1. Select Palette from the Edit menu if the palette is not displayed.
  2. Specify the scale percentage.
    The default value is 100%; change the value in one of the following ways:
    • Double-click in the Scale Percentage field and type the number
    • Click the arrow buttons
    • Drag the slider
  3. Click the Scale tool.
    Image Viewer scales the image according to the value in the Scale Percentage field.
  4. To restore the image to its last-saved size, click Revert.
