Select the message to be printed.
Shift+Click selects several messages in a row by moving the highlight up or down the Message Header List. Control+Click selects discontiguous messages from the list, one at a time.
Choose Print from the Message menu.
Set the options you want to change:
Type a new printer name in the Printer field.
Indicate the number of copies in the Copies field.
Type a banner page title in the Banner Page Title field.
Select Print Page Numbers to print page numbers in your document.
Type print command options in the Print Command Options field.
Click Print.
