Use this procedure if you have saved a message as a draft, but no longer intend to send it.
Choose the draft from the Continue Composing Draft on the Compose menu.
The New Message dialog box is displayed containing the draft message.
Re-address the message to yourself and click Send.
The New Message dialog box disappears.
When the message arrives in your Inbox, delete it.
If your workstation has experienced system crashes while Mailer was running, you may also notice drafts named DeadLetter1, DeadLetter2, and the like. You can delete these drafts by deleting the corresponding files in the $HOME/MailDrafts folder.
