You can use the Edit menu options in a Compose window to change the message text you are composing.
Table 8-5 Mailer Compose Window Editing Options
Undo |
Reverses the last editing action in the text area. |
Cut |
Removes the selected text and stores it on the clipboard. Only one selection can be stored at a time. If text is already there, the most current selection overwrites it. |
Copy |
Stores a copy of the selected text on the clipboard. Only one selection can be stored at a time. If text is already there, the most current selection overwrites it. |
Paste |
Inserts the contents of the clipboard at the insertion point. |
Inserts the contents of the clipboard at the insertion point surrounded above and below by Begin and End Included Message text, or by indented markers. |
Clear |
Removes the selection and leaves the resulting white space. |
Delete |
Removes the selection and the resulting white space. |
Select All |
Selects all the text in the text area. |
Find/Change |
Opens a dialog box for you to search for words or phrases in your message and make changes to occurrences that are found. |
Check Spelling |
Runs the spelling checker on your mail message and displays a dialog box that lists words that might be spelled incorrectly. You can Find, Change, or Change All instances of a word. |
For more information on editing functions, see Chapter 10, Using Text Editor .
