Choose Setup from the Options menu.
Performance Meter displays the Setup dialog box.
Select the Remote radio button to indicate that you are about to type the name of a remote host.
Type the system name (for example, jupiter
) or the IP address (for example, 129.156.220.133
) of the remote host.
To find a host, use Address Manager with Hosts selected on the Find menu.
Click Apply to make your changes take effect.
Performance Meter accesses the remote host and displays its performance. The system name on the title bar of the Performance Meter main window changes to the name of the remote host.
